Wys³any: 2012-06-01, 15:40   Micra Pawel1108
Micra po lekkim daszku,calak
szpachlówki POLYKAR :spoko:
podk³ady Novol Spectral Under385-epox
akrylowy Spectral Under355
baza DYNA - SATA 3000HVLP WSB 1,7atm
lakier Novol Professional 590 2+1+10% dwie norm.warstwy SATA 3000RP 1,3 2,4atm
http://screenshooter.net/1065671/ymieafo
http://screenshooter.net/1065671/oqdrxiy
http://screenshooter.net/1065671/sgjrndv
http://screenshooter.net/1065671/ckryaar
http://screenshooter.net/1065671/xmcbkou
http://screenshooter.net/1065671/vojudwm
http://screenshooter.net/1065671/ktxsdmg
http://screenshooter.net/1065671/uadoxou
http://screenshooter.net/1065671/ujnqrfv
http://screenshooter.net/1065671/mprrknl
http://screenshooter.net/1065671/jobjwcd
http://screenshooter.net/1065671/vryrjts
http://screenshooter.net/1065671/ahtidvw
http://screenshooter.net/1065671/fsalohv
http://screenshooter.net/1065671/batroow
http://screenshooter.net/1065671/bqdslcq
http://screenshooter.net/1065671/bcwquie
http://screenshooter.net/1065671/mlcbjju
http://screenshooter.net/1065671/ppdrboy
http://screenshooter.net/1065671/nbsijhd
http://screenshooter.net/1065671/kyddjfu
http://screenshooter.net/1065671/fstjcki
http://screenshooter.net/1065671/bvcfqdl
http://screenshooter.net/1065671/oaowawc
http://screenshooter.net/1065671/pyipqyc
http://screenshooter.net/1065671/yseraxu
http://screenshooter.net/1065671/pmwxvph
http://screenshooter.net/1065671/qildtha
http://screenshooter.net/1065671/oinpymk
http://screenshooter.net/1065671/rfidcrx
http://screenshooter.net/1065671/lultkgg
http://screenshooter.net/1065671/eoeqqyl
http://screenshooter.net/1065671/ocbqcxf
http://screenshooter.net/1065671/aowjlcr
http://screenshooter.net/1065671/uldlsiu
http://screenshooter.net/1065671/siimgor
http://screenshooter.net/1065671/djvajsy
http://screenshooter.net/1065671/xdugwde
http://screenshooter.net/1065671/vordgdu
ale siê nawrzuca³em,mam nadziejê,¿e linki dzia³aj±.
Pozdro :spoko:
Wys³any: 2012-06-01, 15:46
¶wici siê jak psu jaja :spoko:
jarbia
Wys³any: 2012-06-01, 16:55
Hobbysta ,amator
Sk±d: Wlkp.
pawel1108 napisa³/a:
Dysza chyba do wody baza te¿ ,czy konwencjonaln± malowa³e¶ ?
Na efekt a¿ mi³o popatrzeæ .
pozdr.
- Lew To³stoj
Wys³any: 2012-06-01, 17:33
A co zrobi³e¶ z tamtym :fiu: lakierem bezbarwnym? :x:
Robota profeska.
Piknie baza roz³o¿ona.
Masz fajn± jako¶æ fotek mistrzu Pawle.
Wys³any: 2012-06-01, 18:03
praca ³adna ale ja bym siê przyczepi³ do braku nissanowskiej struktury lakieru niestety, no chyba, ¿e fotki jej nie ukazuja;P
grzechoo2008
Wys³any: 2012-06-01, 19:54
Wielki szacun za ilo¶æ i jako¶æ pracy. Robota klasa :spoko:
A jakby tak jeszcze zainwestowaæ w wiaderko ¶nie¿ki lub cieszynki w kolorze bia³ym na ¶ciany to by by³o lux ;P
Wys³any: 2012-06-01, 20:14
czeka sobie na tematy ¿e tak powiem szybsze i mniej wymagaj±ce,wiesz pewnie o co chodzi ;)
www.lakiernik-wroclaw.eu
Wys³any: 2012-06-01, 20:15
grzechoo2008 napisa³/a:
dobry pomys³ bo trochê wstyd :blee: jak siê zrobi trochê luzu to pomalujê :)
Wys³any: 2012-06-01, 20:18
jarbia napisa³/a:
konwencja to jest ,pierwszy raz robi³em bazê WSB i jestem bardzo zadowolony,
Wielkie podziêkowania dla Krzysia Lackdoctora za doradztwo w tej kwestii :piwo:
kubazjan
Wys³any: 2012-06-01, 20:47
nooooo....robota elegancka :spoko: :fiu: ...baza klasa i klar tez....Powiedz mi szanowny kolego jak Ci sie tak ³adnie baza rozk³ada i na jakim strumieniu to k³adziesz...U mnie ostatnimi czasy na bazie wychodz taka jakby kaszka...nie chce sie franca ³adnie po³ozyc.Wiem ze to wina dyszy,mia³em kupic 1.3 ale nie wiem czy 1.2 nie by³a by lepsza.Sam mam Sate 3000 RP i wiem ze to wymagajacy czystosci gun bo kazdy paproch albo krzywizna iglicy robi potem takie cuda jak mój ^^
Czekam na sugestie jaka dysza by³ by najlepsza...bo w tym tygodniu mam zamiar cos zakupic...
Duza 5 z plusem za robote.... :spoko:
Wys³any: 2012-06-01, 21:23
ja wcze¶niej bazê robi³em GTI110,potem Sata 3000 rp 1,3 i te¿ zawsze jaka¶ smuga,chmurka itp...
a¿ w koñcu naby³em Sata 3000 HVLP z dysz± WSB i muszê powiedzieæ dla mnie rewelacja,¿adnych chmurek,zbêdnych odkurzy pierwsza liga,Bazê na Mikrze robi³em na dwie mokre warstwy,ci¶nienie ok 1,7-1,8 atm,miot³a na max,towar prawie max,normalnie wychodzi³o jakbym akrylem jakim¶ lakierowa³.Ja polecam dyszê WSB w Hvlp.na ca³± Micrê zu¿y³em jakie¶ 0,9 bazy + 0,5l rozpucha Dyna,z tym,¿e tylny zderzak i prawy bok cieniowane.Maska z dwóch stron,lewa wnêka i próg ca³a.
Chali68
Wys³any: 2012-06-01, 22:50
I tak powinno to wygl±daæ! Pe³en pozytyw!
kubazjan
Wys³any: 2012-06-01, 23:08
aaa...to juz rozumiem...podumam jeszcze co tu zakupic.U mnie miot³a jak jest na maxa i materia³ tez to zapomnij o jakimkolwiek rownym po³ozeniu...rzuca placki ciemniejszej bazy i grubszej pow³oki...Na ciemnych to jeszcze jakos ujdzie ale na srebrach to juz jest dupa i tzreba kombinowac.Potem to samo jest z klarem ale tam juz jest ³atwiej...No ale juz niebawem mam nadziej ze to sie zmieni...pozdro.
POLYKAR.PL
[Usuniêty]
Wys³any: 2012-06-01, 23:11
sorrry wielkie , ale na ostatnim zdjêciu widzê dwa pistolety .... jak to piszecie "guny" .... hmmm ...
a masz Pawe³ zezwolenie na broñ ??? I to podwójne ???
¯arcik oczywi¶cie - wysz³o super . Jako oczywi¶cie laik mogê pogratulowaæ :-) .
Wys³any: 2012-06-03, 23:58
kubazjan napisa³/a:
Do bazy z pewno¶ci± 1.2 w RP :tak: Wymieñ w koñcu kolego ten zestaw ;) poprawisz sobie jako¶æ pracy :tak: A tak to tylko siê mêczysz ;)
Ja te¿ kolego Pawle :tak: :spoko: :spoko: :spoko:
MARKOPOLOVW
Wys³any: 2012-06-04, 06:51
Pawle1108, czy mo¿esz zdradziæ jak filtrujesz powietrze ze sprê¿arki? na fotach widaæ bardzo czyst± pow³okê...czy masz osuszacz powietrza? Robota 1 klasa, bardzo ³adnie przygotowana, sikniêta piêknie a pow³oka jeszcze ³adniejsza. Chyba ¿e u¿ywasz jaki¶ dobrych filtrów. z góry dziêki za podpowied¼
pozdrawiam
kubazjan
Wys³any: 2012-06-04, 07:52
Robert wiem ze juz dawno powinienem zmienic t± dysze ale za cholere nie moge jej nigdzie znalezc albo ceny z kosmosu s±...Jak mam wydac 500-600 za dysze to juz sie czasem zastanawiam czy nie lepiej za taka kwote kupic Air Gunse...ale poczekam jeszcze troche.
stek
Wys³any: 2012-06-04, 08:37
Sk±d: ok kraków
Witam, @pawe³1108, jak sprawa sie ma do wtr±ceñ, robota super,Pozdr.
Wys³any: 2012-06-04, 08:39
MARKOPOLOVW napisa³/a:
pewnie :spoko:
filtr wstêpny SATA 444,wk³ad ze spiekanej tulei br±zu,potem blok filtrów CKD 4000,czyli wstêpny 5micronów i dok³adny 0,1microna.
Osuszacza jeszcze nie mam ale wci±¿ na niego chorujê, trochê muszê zaczekaæ bo zmieni³em kompresor z ASPA na Walter GK630-4.0/270 i zauwa¿y³em,¿e kraterków jest o wiele mniej ni¿ przy ASPIE która rzyga³a olejem.
Aczkolwiek to powietrze nie jest super czyste ,bo na ca³ej Mikrze s± z 3-4 oczka.
Osuszacz bêdzie ale niestety nie wszystko na raz,po woli do przodu,oby nie w ty³ :spoko:
Wys³any: 2012-06-04, 08:41
stek napisa³/a:
zawsze trochê w norce jest,ale siê powycina ;)
gwiazdka 2000,trizact 3000,3M zielony,czarny,polishROSA i bêdzie dobrze :spoko:
Wys³any: 2012-06-04, 08:44
kubazjan napisa³/a:
Kolego poszukaj sobie u¿ywanej Saty,z pewno¶ci± ok 1000z³ kupisz,nie cofaj siê do Airgunsy,id¼ do przodu
http://allegro.pl/sata-je...2365976147.html
zadzwoñ pogadaj,cena dobra a i stan ³adny,tyle,¿e bez Digitala ale WSB
MARKOPOLOVW
Wys³any: 2012-06-04, 09:43
a czy ta SATA z dysz± wsb jest tylko do wodnych?konwencj± siê nie pomaluje?szukam saty hvlp ale do konwencji a z tego co piszecie to siê nie sprawdzi co?
Nokia
Wys³any: 2012-06-04, 09:55
Sk±d: Silesia City Center
By¶ poczyta³ ten temat od pocz±tku to juz by¶ wiedzia³ ze lakierowa³ to konwencj±.
Wys³any: 2012-06-04, 10:11
ja j± po to naby³em,w³a¶nie do konwencji,tak¿e siê nie zastanawiaj,bêdziesz zadowolony :spoko:
ComTom
Wys³any: 2012-07-01, 14:11
£adnie polakierowane mam jednak pytanko co jest przyczyna tych plamek w bazie ??
http://scr.hu/6oy/qev5i
Ja mia³em co¶ takiego jak niedostatecznie rozcieñczy³em bazê ale tutaj jest to miejscowe co jest tego przyczyna ??
Wys³any: 2012-07-01, 15:10
ComTom napisa³/a:
nie mam pojêcia bo niczego takiego na aucie nie ma,mo¿e wina aparatu lub zdjêcia?
nie posiadam pojêcia :)
jedi9
Wys³any: 2012-07-01, 20:33
Sk±d: ¯yglin
ha a ja wiem co to jest :P odbicie :) przy tak ³adnym lusterku zrobi³o siê "lusterko"
JAROGTS
Wys³any: 2012-07-01, 23:26
Sk±d: Bia³ystok
A ja spytam co to ta gwiazdka do usuwania wtr±ceñ?
ps. jedi gdzie s± fotki?!:D
Wys³any: 2012-07-02, 07:43
to s± p³atki do usuwania wtr±ceñ P1500,P2000,P2500
http://screenshooter.net/1065671/kvntbeb
pozdro
ComTom
Wys³any: 2012-07-02, 19:01
te platki sa tez 3000 i 5000 jak ktos chetny moge zalatwic
